lee webster
I looked very carefully at my printer settings and changed them. My last few prints were using the default settings. When the build plate is lowered into the resin vat and then raised, it can cause a lot of suction. I slowed the raising of the plate between layers to reduce the effect of the suction. I also increased the time between layers so that the UV light would have more time to set the layer of resin. I set it to print and walked away. 2 hours later I had a look at the progress and there was only 4 minutes left to completion. I could just see part of the build plate and it seemed to have things hanging from it. All 4 parts had printed almost perfectly. I say almost because the surface finish where the supports were was awful. It looked like the skin on a rice pud. The parts were washed and cured and left to sit for a while. Some of the parts had 4.1mm holes for set screws. A 4mm set screw slid in with hardly any play. 2 of the parts had flanges on to locate in a recess in another of the prints. They were a good fit in the CAD programme, but oversize on the prints. I can live with the rough surface, it's on a face that isn't used, the holes are OK, maybe a little snug. But the flange fit is something of a concern. I think I might do away with the flanges and introduce holes for a dowel.
So, how accurate do you think a resin print shoud be?
