2Zylinder marine steam engine
Hello to all
Since I have no English can translate Google.
I have this engine built from plans by Duval from France.
Some data:
Bore 16 mm
Hub 19 mm
Flywheel d 40 mm
Area approximately 80 x 140 mm, height 140 mm
Weight 1.6 kg
After a running time of 2 hours is the small machine
quietly and smoothly, even at low pressure and it amazes me how much force it takes at the stripe. The reversal also works perfectly,
However, it must be for control by a servo rebuilt.
For the actual construction of the machine I need not write further,
There are the usual rotation and milling operations have been described in detail in the forum already. Some parts of me have my CNC Fräschen made​​.
The replica has given me a lot, despite the many items Joy
and now I finally have a well-functioning two-cylinder steam engine, the ship maybe their work in a steam boat
will perform.
Greetings Manfred
Hello to all
Some data:
Bore 16 mm
Hub 19 mm
Flywheel d 40 mm
Weight 1.6 kg
will perform.
Greetings Manfred
