I am about to build a "shock box" consisting of a 12 volt automotive coil, a 12 volt dry cell battery and a switch, with two electrical leads to go to the internal battery and two to go to the engine and ignition points, with one high tension lead which goes out to the spark plug. This "shock box" will be used to run a number of different i.c. engines.
The only coil I can buy at local automotive stores all have written on the case "Use with external resistor".---Now if I remember correctly, an external resistor allows a full 12 volts to the coil to allow maximum spark for cold engine starts, and then as the external resistor heats up from current flow, the voltage is gradually cut down to 8 volts flowing to the coil, which supposedly let the ignition points last longer. Since none of my small i.c. engines will run for longer than 1/2 an hour at a time, I don't believe I need to bother with the external resistor (Which my auto parts store can't find a source for anyways).---Any opinions on this?---Brian
