ChooChooMike
- Jan 5, 2008
- 863
- 13
10 Ways Engineers Can Improve The Machinability Of Their Parts
Article Link
10. Double check your drawing. Often the default on some design software is actually a very difficult feature to make. Do you really need a bottom tapped hole?
9. Spend a few days with the QA department the first time they qualify your new part. It will be eye opening.
8. Can you explain concentricity, how it affects the bore on the axle you are having made, and how QA should measure it? If not, take a class on Geometric Dimensioning and Tolerancing (GD&T). (tip: This is a tough thing to learn without Q&A, but here is a good book: Geometric Dimensioning and Tolerancing for Mechanical Design: A Self-Teaching Guide to ANSI Standards)
7. Walk through your design with a machinist, and explain your intention behind major decisions. This will help him identify features you can adjust to improve machining efficiency.
6. Parts that dont fit together are a lazy engineers fault. Dont always blame the machine shop. Double check your tolerance stackup, and then check it again. Visualize it. Then, write it down. Dont just use your calculator.
5. If the material isnt crucial, choose the easiest to machine. Machining time is usually more expensive than the material. (Check out 12L14 Ultra Machinable Carbon Steel)
4. Ask a machinist which features of your part are the most challenging to machine, and then go simplify them.
3. Tell your machinist which features are absolutely necessary and which can be tweaked. Hell have some good suggestions to improve the machinability.
2. Spend a few days helping a machinist make one of your more complex parts. You will learn things you never even thought of.
1. Encourage feedback from the machine shop and get as much of it as you can. Dont be the engineer that takes offense to suggestions regarding your designs.
Article Link
