George Punter
Active Member
George.
George that is an impressive task to take on .I am familiar with the McDonald tractor as i grew up on a wheatfarm in central wheatbelt of WA .It was and still is a running tractor in a small museum now on loan .I will be following this thread with much interest as they are one of my favourite vintage tractors. I cant still remember the starting sequence of our McDonald .check all fluid levels then unscrew the relief plug on side of the cylinder head give it a few turns by hand .Then screw the relief plug back in while heating the bulb .Give the oiler box a few turns by hand .Wait for the heat bowl to heat up cherry red .Give a the injector a good squirt by hand then start rocking flywheel and bang she would pop into life usually the wrong way haha .Once it was running if you could slow it down and get the engine to fire back the other way if you were quick on the throttle .View attachment 109590 View attachment 109591 View attachment 109589 What a difference a couple of days make - some rubbing down and a few coats of spray bog on the engine crankcase /cylinder barrel pattern. I now have to make the core box to create the internal space inside the engine and that entails engage brain into negative thinking!
If any one our there has information / plans of the gearbox and the cylinder head it would be appreciated. I have a plan of the gearbox but no side elevation to show the position of the reverse gear and shaft. The photo shows the full size Mc Donald (1934) tractor.
George.
Hi GeorgeThanks Nat for the information on the Mc Donald tractor manuals etc. I will make contact with the seller soon with a view to ordering the most suitable book. I think a phone call will give me the opportunity to discuss the content of the books and my needs. I appreciate the help. I was pleased to hear you are about the purchase a lathe - is that with a view to taking up model engineering? I have been making some progress on the development of the engine, focusing on the cores for the inside of the cylinder and crankcase. As the cylinder and exhaust port are set at ten degrees to the horizontal and the outside of the port is vertical there is a twist in the actual rectangular port opening. I plotted all of this on CAD and then produced a split core box on the 3D printer. That’s technology for you - makes life a great deal easier! I will add to this post as and when I develop the next stage.
George.
Mainly interested in Small engines George .I have made a couple of Air and steam engines now and looking at starting on a webster ic engine soon .I make a lot of my own tooling and am set up to machine gears ets and have done so in the past .My work shop in Thailand is quite well set up with qite a lot of equipment .A 12x36 lathe ,zx47 mill with indexing head and a load of welders and tooling .The lathe i am looking at here in Perth is to start setting up a small hobby machine shop in our house in Perth .You may ask why i want a machine shop in Thailand and one in Perth the reason being is that over the next few years i can see myself bouncing back and forth between the two as my work slows down and also for my daughtets schooling etc as she gets older .Nat what area of model engineering are you interested in ? As a teacher in the UK before I came to Australia our workshops were equiped with Boxford lathes but later I taught in a large comprehensive school and that was equiped with Colchester Student lathes and also had the luxury of a Senior milling machine. As at that time my home workshop consisted of a Myford ML 7 and a Black and Decker portable drill the school workshop became a real asset! I don’t know what value you put on the machinery you are looking at as it depends on condition. The competition is also that Taiwan makes some good lathes at reasonable cost. Hare and Forbes ( in Queensland ) carry a wide range in both size and cost and it may be worth looking them up on the net to give you any idea of value.
George.
