If look at the lettering on casting of the Astrolabe it is hundreds years The look photo paper it has plexiglass cover for today's a lot easier than hundreds years ago[/b]
This is a Astrolabe hundreds of years old note: All bronze/brass casting with fine lines
Note conter weight.@ bottom. Then ring at top is for finger this keeps the As leave
The fine lines are easy to read. For other projects need divions.
Here is being a photo paper the photo print uses plywood or metal base. This can be made weather proof with a sealant.
Note: all scaled used.
6 scale for 20° 35° ,40° 45° & 55° Latitude Theblast one is Southern Hemisphere on 35° latitude.
Degrees for angles 0°-180° ,0°-90°- 0° & 90-0-90° . Then photo paper first made in Autocad simple essay changes. Protractor is a aluminum this is precision manufactured and easy to come by.
This can used as plaques on engines , switch panel and gauges
After post 9 will have more data on Name plates and plaques.
If sitting around the Potbelly stove on a cold winter day while talking about Engines and shop related or any that needs a engines or topics appeals to you please post .
The Sundial and Astrolabe a shows different over the centuries
Still talking about fun little projects like Sundial and Astrolabe . Shows different was used on casting over cent
Starting on post 5
Building a sundiel and Astrolabe.
A face for both Astrolabe and sundial.
Sundiel has 20 to 55 latitude primary Northern Hemisphere and Southern Hemisphere
sundial with dates.
![R (2).jpeg R (2).jpeg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/116/116022-R-2-.jpeg)
![Sundial 2 Dec 19 2024.jpg Sundial 2 Dec 19 2024.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/116/116584-Sundial-2-Dec-19-2024.jpg)
![Sundial Dec 319 2024.jpg Sundial Dec 319 2024.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/116/116585-Sundial-Dec-319-2024.jpg)
Starting on post 5
I have posted information on tags , name plates , plaques and other brass nameplates, cast plaques , embossed/debossed and fixing old nameplates using Sharpie use years ago indown loads added detaileds on nameplates repairs.
sundial with dates.
