Nameplates, Plaques w/Navigation and sundiel because of health.
SmithDoor
Staff member
Global Moderator
Clovis Ca
If look at the lettering on casting of the Astrolabe it is hundreds years The look photo paper it has plexiglass cover for today's a lot easier than hundreds years ago[/b]
This is a Astrolabe hundreds of years old note: All bronze/brass casting with fine lines
Note conter weight.@ bottom. Then ring at top is for finger this keeps the As leave
The fine lines are easy to read. For other projects need divions.
Here is being a photo paper the photo print uses plywood or metal base. This can be made weather proof with a sealant.
Note: all scaled used.
6 scale for 20° 35° ,40° 45° & 55° Latitude Theblast one is Southern Hemisphere on 35° latitude.
Degrees for angles 0°-180° ,0°-90°- 0° & 90-0-90° . Then photo paper first made in Autocad simple essay changes. Protractor is a aluminum this is precision manufactured and easy to come by.
This can used as plaques on engines , switch panel and gauges
After post 9 will have more data on Name plates and plaques.
If sitting around the Potbelly stove on a cold winter day while talking about Engines and shop related or any that needs a engines or topics appeals to you please post .
The Sundial and Astrolabe a shows different over the centuries
Still talking about fun little projects like Sundial and Astrolabe . Shows different was used on casting over cent
Starting on post 5
I have posted information on tags , name plates , plaques and other brass nameplates, cast plaques , embossed/debossed and fixing old nameplates using Sharpie use years ago indown loads added detaileds on nameplates repairs.
Building a sundiel and Astrolabe.
A face for both Astrolabe and sundial.
Sundiel has 20 to 55 latitude primary Northern Hemisphere and Southern Hemisphere
sundial with dates.
    322.8 KB
    294.3 KB
    178 KB
Here how dial looks for Navigation and sundiel face. . This Great way to plates on tools and engines.
Working on improve version the letters are little
Them
This how the dial will look when finished a plexiglass covers to protect the photo paper. The protractor is top for most accuracy. I have used this pass different projects. First try lacquer later used plexiglass with gave a good protection.
Works for machine tools and engines too.
The lacquer work but some time the lacquer would give fussy lines. I did use a artistic spay paint then lacquer. This was better but plexiglass was best for fine lines. If was in damp or wet I would use silicon on edges for better seal.
I have casting, photos and offset printer plates too the down side was time it took and cost.
Cast aluminum Plaque
Using a Manufacture Protractor saves time.
Doing in mill takes time
Note I have not removed the ruler in this photo.
Here is photos of one project. Using photo paper and plexiglass
Finish Using photo paper and plexiglass.
Update on face plate. Finally finished with sundial and Astrolabe cobo dial.
If you closely at dial you will latitude form 20° to 55° with southern Hemisphere. The degree number for 180° on protractor the on chart 0 to 90° - 0° both ways then center 90° , 0° -90°
This for making Earth correction for sundial. Astrolabe uses and finding hight of objects.
The wen protractor is for more accurate can be read to ¼°. If veneer is used easily to 0.1° or 10 minutes.
This a fun little project in the Break Room​
It for navy engines
Please post comments on this PROJECT​
The PDF is so you closer look and for your own projects.
  • 1A) SUN WATCH DEC 12 2024 Model (1).pdf
    78 KB
