Hi
Here are some screen shots of my slant bed CNC lathe. The design I have taken a bit here and there that I have found around.
The spindel is turned from a 120 mm solid bar. Spindel bearings are double angular contact bearings on chuck side and deep grove ball bearings on drive end.
Frame plates are 20mm, ribs are 15 mm. All screwed together. No welding in order to avoid stress and tension.
Rails are 20 mm and ball screws are 16 mm with 5 mm pitch.
Motors x and y are NEMA 32 direct coupled to ball screws.
Base are made of 80 mm alu profiles.
